Root Need help please...
So I installed WildCard Rom...Updated my profile under system updates...Now i have no service. Tried wiping everything. Please help.
ive herd that updating yo profile will break something so u not suppose to do it on that rom but ive never used wild card so i might be wrong. just wait until one of the people on here that has use it comment and help u out
there is a thread started with the title "No Service after PRL/profile update"
The op had the same issue...and its been resolved.... When I found it a minute ago it was post 142, on my phandroid app (sorry can't link it)
I got it to work!
First flash the ruu from bootloader that adamhoss1234 posted.
Install OTA update (under system updates, update software) while on wifi.
after that's done dial ##25327# -menu-reset and wait 'till it boots up and it should work.
I got it to work!
Is this going to be a pain in the ass to do?
If you have your stock Rom backed up, you could try restoring that nandroid then try the clear menu and reset, its worth a shot anyway
