Help need help reseting my htc hero
joshnosh
basicly i lost my phone ages and clamed on insurance
then i found it at collage a few weeks later
so the phone is imei blocked but still a great peice off kit.
i know i should probably give it back to the insurance company but my insuracne company is the scum off the earth so they can go screw themselves :)
so i loaded some songs on it and used it as and ipod for a while but then for some reson whitch i cant remeber now, i did a factory reset on it and when i turn it on it screws at my to put a sim card in to "place calls" but if i do it says blocked or something similar due to the IMEI block.
any way i can get round this? i dont mind trying to root or somthing like that if it will help
if the insurance company got you a new phone then why do you need to make calls with the old one
If the phone is blacklisted by the insurance/wireless carrier then it's pretty well a done deal! Short of doing something illegal, there aren't many options available to you to get around this. Sorry!
Really? They replaced your phone, didn't they? :rolleyes:
As the IEMI is blacklisted across all networks to prevent fraud/misuse there's no way round it. It's just something you'll have to put up with, I'm afraid.
