Root NEED HELP ROOTING DHD running on 2.3.3
milleon
Hi Guys, Im new here need help in rooting my DHD
Android Version 2.3.3
HTC Sense Version 2.1
Baseband Version 12.54.60.25U_26.09.04.11_M2
Kernel Verison : 2.6.35.10-gd2564fb
Build Number : 2.50.707.4
Software Number: 2.50.707.4
I tried following this instructions - http://androidforums.com/desire-hd-...b-build-downgrade-1-32-405-6-easy-follow.html
But for some reason after downloading busybox and SU
and follow the CMD prompts i get an error of ADB not found
debugging mode is enabled and im stuck i really need help regarding this
and also when i run SU on my phone - SU binary is outdated and for some reason i cant update as well
any help would be appreciated
thanks!!
do i need to hold down the volume-down button? if i do rooting wont work for me... physical button is shot for some reason...
still getting an error - "adb is not recognized as an internal or external command,operable program or batch file" my goodness getting really stupid at this help please!!
Try to download adb driver zip for htc.then extract to a specified folder in your computer eg.desk top.;)
I'll read up on the requirements when I get home from work. As it stands, that's a fairly new process to me so I don't know the ins and outs of it.
As per a few posts up, you're gonna be limited to what you can do anyway if your volume down key is broken as that's needed for accessing the bootloader (unless you have the SDK installed) and navigating your way around clockwork. I'd sort that before you start rooting.
hi,
i'm trying this method.
so far have got to....
Ace Advanced Hack Kit [Linux/OSX/Windows] attn1 2011
___________________________
MAIN MENU | |
| Only ONE Step to: |
1 - Hack Ace <----------------------------+ * S-OFF |
| * SIM Unlock |
2 - DONATE (Encouraged, but optional) | * SuperCID |
Free HTC goldcard generator | RevSkills | * Root |
http://www.eff.org/ | * Busybox |
| * ClockworkMod |
o - Options Menu (Return to Stock, Flash radios, etc)
t - Toggle Flash Method - current method is fastbootRUU
q - Quit
[Select and press Enter]1
2649 KB/s (4359771 bytes in 1.606s)
pkg: /data/local/tmp/stericson.busybox-1.apk
Failure [INSTALL_FAILED_ALREADY_EXISTS]
1203 KB/s (19232 bytes in 0.015s)
2597 KB/s (4564992 bytes in 1.716s)
2156 KB/s (3686400 bytes in 1.669s)
2686 KB/s (557962 bytes in 0.202s)
9 KB/s (9796 bytes in 1.000s)
15 KB/s (15837 bytes in 1.000s)
2804 KB/s (134401 bytes in 0.046s)
13 KB/s (13968 bytes in 1.000s)
ro.build.version.release=2.3.3
Setting up for Gingerbread restore...
2505 KB/s (2801664 bytes in 1.092s)
2531 KB/s (2830336 bytes in 1.092s)
2237 KB/s (285981 bytes in 0.124s)
1790 KB/s (285981 bytes in 0.156s)
1 file(s) copied.
Linux version 2.6.35.10-gd2564fb (htc-kernel@and18-2) (gcc version 4.4.0 (GCC) )
#1 PREEMPT Thu Jun 9 14:20:29 CST 2011
Kernel version is Gingerbread... Using fre3vo to temproot...
fre3vo by #teamwin
Please wait...
Attempting to modify ro.secure property...
fb_fix_screeninfo:
smem_start: 802160640
smem_len: 3145728
type: 0
type_aux: 0
visual: 2
xpanstep: 0
ypanstep: 1
line_length: 1920
mmio_start: 0
accel: 0
fb_var_screeninfo:
xres: 480
yres: 800
xres_virtual: 480
yres_virtual: 1600
xoffset: 0
yoffset: 800
bits_per_pixel: 32
activate: 16
height: 106
width: 62
rotate: 0
grayscale: 0
nonstd: 0
accel_flags: 0
pixclock: 0
left_margin: 0
right_margin: 0
upper_margin: 0
lower_margin: 0
hsync_len: 0
vsync_len: 0
sync: 0
vmode: 0
Buffer offset: 00000000
Buffer size: 8192
Scanning region faa90000...
Scanning region fab80000...
Scanning region fac70000...
Scanning region fad60000...
Scanning region fae50000...
Scanning region faf40000...
Scanning region fb030000...
Scanning region fb120000...
Scanning region fb210000...
Scanning region fb300000...
Potential exploit area found at address fb310e00:1200.
Exploiting device...
0+1 records in
0+1 records out
384 bytes transferred in 0.001 secs (384000 bytes/sec)
--set_version set. VERSION will be changed to: 1.31.405.6
Patching and backing up partition 17...
Starting update process....
erasing 'cache'... OKAY [ 0.203s]
finished. total time: 0.203s
Be patient - sending update ...
sending 'zip' (18223 KB)..."
it's been sending 'zip' for 17 mins now.
this is 4th attempt.
any idea how long it should take?
manual says should be done in 6 mins
hi,
MAIN MENU | |
| Only ONE Step to: |
| * SIM Unlock |
| * ClockworkMod |
q - Quit
1 file(s) copied.
fre3vo by #teamwin
Please wait...
fb_fix_screeninfo:
smem_len: 3145728
type: 0
type_aux: 0
visual: 2
xpanstep: 0
ypanstep: 1
line_length: 1920
mmio_start: 0
accel: 0
fb_var_screeninfo:
xres: 480
yres: 800
xres_virtual: 480
yres_virtual: 1600
xoffset: 0
yoffset: 800
bits_per_pixel: 32
activate: 16
height: 106
width: 62
rotate: 0
grayscale: 0
nonstd: 0
accel_flags: 0
pixclock: 0
left_margin: 0
right_margin: 0
upper_margin: 0
lower_margin: 0
hsync_len: 0
vsync_len: 0
sync: 0
vmode: 0
Buffer size: 8192
0+1 records in
0+1 records out
I got stuck at this bit as well mate. Are you sure you have uninstalled all phone pda and tablet software from your pc. I forgot to take of my Asus tranformer software when i figured that ot every thing went fine
htc bmp usb driver would be the only thing i might have missed.
would that be it do you reckon?
Have you tried getting another copy of the hack kit? Maybe it could be something like the one you downloaded was slightly corrupted. I know it's a long shot (and someone should correct me if i'm wrong about it) but that could fix it
hi again,
well, i've tried using the method found here:
http://androidforums.com/desire-hd-all-things-root/420774-has-anybody-rooted-using-tool.html
6 times so far.
seems to run ok until the 'sending image' stage.
then hangs.
i've also tried the method found here:
5 times.
again, seems to run fine.
until bootloader says can't find image. or wrong image.
<sigh>
i just can't figure out what i'm doing wrong??
could it be the sd card?
it's a 2gig one that was lying about.
i thought i'd use that instead of 16 gig i have in phone.
clutching at straws now :/
Is all phone software gone from the PC, HTC Sync etc? It's recommended to use the Ubuntu Live CD as it's the "cleanest" environment.
Download | Ubuntu
Boot into there and run the hack kit from there.
thanks mate!!
it is, as far as i can tell.
will give that a try.
might be making myself look stupid, but that version of hack kit seems to be a windows download.
is there another version anywhere?
cheers :)
I'm sure there are .sh commands in there which are linux executables/cmd files. I did download the hack kit to see what it contained and what the deal was, but deleted it last night, sorry. :rolleyes:
finally.
got the advanced hack kit to work.
not sure if it was the recent update, or i did something i should have done originally, but who cares :)
