Root need help unrooting the g2 with no screen
edc2
hello everyone i need help with unrooting my g2. the problem is the screen died out on me it went all black and had vertical white lines and tmobile agreed to replace it under warranty they said it was a defect but im afraid they will blame it on me since it was rooted. can anyone help me?
thanks in advance
You should he able to unroot via adb. I don't have this device but its Linux and as long as you can find the zip of the original o.s. you should be fine. Its a bit longer of a process visit the emulator but it has the desired end result. Good luck man
