Root Need help unrooting
gorogjm
I need to unroot my phone. I didn't use gingerbreak. Instead I typed this into the terminal emulator:
sudu
Press "enter"
ln -s /system/xbin/sudo /system/bin/su
Press "enter"
ln -s /system/xbin/sudo /system/xbin/su
Press "enter" again
How do I unroot?
Hey goro,
I moved your post to it's own thread as it would fit better that way than in the CM7 thread.
I am not sure how you would do that, I used GingerBreak when I first rooted. I am sure some here can help you, just be patient. :)
sudu
Press "enter"
Press "enter"
Press "enter" again
How do I unroot?
Try this (replied this on your other thread too).
Haven't needed to try it myself, though.
sudo
rm /system/xbin/sudo /system/xbin/su
rm /system/xbin/sudo /system/bin/su
sudo
rm /system/xbin/su
rm /system/bin/su
All you need to do is remove the su links and not both sudo and su.
Typing on my phone so I can't type out the whole command but i edited the command in the quote.
