Help Need help with questions
diplomat1
First how do i send ringtones through bluetooth? I put a certain ringtone in the ringtone folder but i cant send it through bluetooth. Is there a app i can download so i can go through all my stuff on my sd card and my phone? And also is there a program that shows whats on my phone and wats stored on my card? and something so i can transfer my stuff from my phone to my card and vise versa. Also i just updated my prl/firmware/profile and then i read that updatin the prl/firmware/profile can actually make my phone slower. Is there any truth to that? Before i did the updates i sometimes used to get text slower for reason like i have someone text me and they say they texted me at like 3:00 but i recieve it at 3:20 or something. That happens sometimes but i dont know why. I also have a good amount of bars (3-4). Any thing you guys can suggest please? Thanks alot
1.not sure about ringtones through bluetooth
2.you can use a number of file managers to look into your sd card. astro files, & es file manager are the main ones i have used.
3.as far as trasfering stuff to and from your phone, just use your computer via usb.
4.those updates are actually supposed to help with speed if anything. they should not slow down your phone.
Yea thats wat i thought if i update the stuff it shoukd be bbetter but someone here said not to update the prl...any truth to that? Also ty for astro suggestion..its great. But does anyone know why i recieve texts late sometimes? Any ideas why and how to fix it? Thank ypu very much
android version
2.2
baseband version
2.15.00.11.19
prl version
01115
pri version 1.90_003
if u need anything else lmk thanks
well it looks like your updated so there is no need to update your prl. what messaging app are you using? you can try and clear out cache for that app if there is any. or maybe try calling or taking it in to sprint and see what they say. i wish i can be of more help.
