Root Need help
i have been trying to flash r3charged rom but it keeps freezing up did 3x wipe on cache dalvik and data and still freezes should i do a wipe all userdata/factory reset? and then re flash the rom?
try vrsuperwipe also, found HERE...
wipe - cache
- dalvik cache
- data
flash vrsuperwipe
flash rom
all in the same recovery...
give that a try...
EDIT - at what point does it freeze on you? are you letting it boot long enough? it could take a while... is your card partitioned?
wipe - cache
- dalvik cache
- data
flash vrsuperwipe
flash rom
give that a try...
my card is not paritioned it freezes up when i get into the market to re download titanium then i pull battery on reboot it wont go past lockscreen
so using that superwipe file is a good idea?
i only use that before i flash a rom. just make sure to wipe at least dalvik cache, cache and data as well then use superwipe then flash the rom. but if you are just having issues on your rom now always try and wipe dalvik cache and cache first. if that does not work then try and again wipe dalvik cache and cache the re-flash the rom. no need to wipe data to re-flash the rom.
ok its booting up now since i didnt get very far when first flashed the rom figured i just do it fresh and wipe everything i wanted to ask tater said there was a 1ghz download file with this rom n i cant seem to find it.. would you happen to know where it is?
no good i cant use it for 5 minutes before it freezes on me n i have to remove the battery is this rom just no good or is there a piece im missing
edit: found the 1ghz file will flash that now
Glad you found the Zip for that. It runs very well once you have the 1ghz zip file.
The way it seems to be set up I don't use SetCpu with it and get very good battery life and have a fast snappy rom.
Enjoy.
Naters
