Need help !
x8forever
Hey, ive had my x8 for almost a year now and ive been using a 2gig micro sd card. i kept managing with that but now i have no choice but to change it. the problem is that i cant see all the files on my computer to transfer to the new sd card.
I can see them on 'astro', my filemanager, but they do not appear on my windows explorer. I have really important files on this.
What do i do??
This does seem very strange as all contents that are changeable can be accessed using Windows Explorer. Can you confirm where on Astro File manager the files are located?
What do i do??
Hi,
Take out your SD Card and use a USB Card reader.
cheers :)
gabe
What do i do??
Your computer might have been infected by a virus that hides files from any flashdrives/memory card... try using "USB SHOW"
