Root Need Help!!
It will be released soon enough for both stock and CM :D I am adding more governors and need to test more thoroughly before I can release
Pretty sure you haven't heard, but I am pretty mean at tearing kernels apart. Ive been known to make phones cry at how hard I test them. Willing to give you a hand...
Hey guys. Need a hand. I messed up twrp trying to install another version over it. I had twrp for c50 installed and tried installing the one in the CM thread over it. I ignorantly did not make a backup and did not wipe anything before flashing. Twrp Manager said the flash was unsuccesful. Now when i try to boot into recovery i get this on the lg logo screen:
Secure booting error!
Error code: 1003
My phone then just reboots back into system. How would i completely remove and reinstall twrp or fix it? Thanks
Hey guys. Need a hand. I messed up twrp trying to install another version over it. I had twrp for c50 installed and tried installing the one in the CM thread over it. I ignorantly did not make a backup and did not wipe anything before flashing. Twrp manager daid the flash was unsuccesful. Now when i try to boot into recovery i get this on the lg logo screen:
Secure boot error
Error code: 1003
Install twrp manager and install from there
I did. Twrp Manager said the flash was unsuccesful. Thats how my issue started. I tried installing the twrp in the CM thread over my current one. Now i cant boot into recovery. I get to the Lg logo and
Secure booting error:
Error 1003
Shows on the screen. I also tried to get into recovery using the key combo. Same error. Is there a way to completely remove and reinstall recovery? Thanks man!
Error 1003
Shoot...
Could someone upload a backup stock recovery.IMG? I never made one like a dummy. Use Rashr, makes a recovery backup nicely
So after trying twrp manager about 10 times to try n install twrp, the issue resolved itself after trying an older version. It still wont successfully i stall the newest version though. Now how do i go about installing the twrp in the CM thread? I would really like to check out CM 12. Thanks for your help dragonhart. Youre awesome man!
This is a UNIX hack... Remove all bank info from your phone... When the time switches to 12/31/00 the hack is almost complete... Again, remove any bank info from your phone. Your welcome
