Root Need info on 2.2.1 differences in kernel
getitnowmarketing
Need some info on 2.2.1. Has radio/baseband version changed from 2.2 to 2.2.1? Also can I get a stock kernel config pull from both 2.2 and 2.2.1?
Code:
adb pull /proc/config.gz
Please upload and label. Im back from android afk and Lg did not release new kernel source for 2.2.1. I want to examine differences so recovery kernel can be updated with source built one and also overclocking etc for 2.2.1.
Code:
I have a phone that came stock with 2.2.1 I rooted it and now im running the rom from teamchickeneater I was going to do as you said here but for some reason im getting a device not connected error not sure why, I do however have a nand backup I made of the stock rom, maybe it will help
I zipped it all up with 7-zip Stock Rom
Here is the config.gz from 2.2.1 stock phone.
Hmmm I just ran across this thread about compiling a bootloader. I'm probably not half the compiler ( is that a real word I don't know :D ) as getitnowmarketing. But this would fix the issue that optimus v users with 2.2.1 preinstalled are having.
I'll go check his youtube channel. If you happen to have a direct link to the video that would help, I would appreciate it. If not, then I will consult Asadullah's youtube channel. Did you happen to remember the particular, video title?
Asadullah has a YouTube video of how to make a ROM. Should help
Ah, then I had not checked his youtube channel since he posted that or I had not checked it thoroughly. Admittedly, I am encumbered with work lately. Thank you for getting back to me.
