Can someone please link or generate a ROM that is in tar. format so I can flash it through ODIN b/c I can't access my Recovery thanks to boot loop.
I actually don't know what that is.... gimme some time I'll do some research on it. What if my phone does recognize it?
OK, In the Android SDK Manager I only Installed the Android SDK Tools and Platform-tools packages. Now I have no idea what to do... (I'm not sure how to tell whether or not ADB recognizes my device)
You can sideload a ROm but if the adb Dont work what will Odin do for you
It will be a waist of time to do a tar file
Are you flashing the correct image and are you flashing in the correct spot in odin where did you get the image from.
What is the full make and model of your device.
What happened to get you in your current state? How did your recovery become corrupt? What is the error message from Odin?
Odin can still see the phone all is not lost YET Odin is the Alpha and Omega when it comes to Samsung devices.
Indeed Odin is the Alpha and Omega, I've had enough of Recoveries, I want to try flashing a ROM or maybe a Kernel through Odin, but I can't find any online.
EDIT* Just tried reflashing TWRP, boot-loop is still exactly the same.
Well, if you are seeing the twrp screen for a brief moment, the timing isn't the issue... Unfortunately, I'm not able to find an Odin system image. I'll try looking around some more, but unless we can find a system image, or get recovery working, I'm not sure what else to try
Odin system image is another name for a ROM in tar. format right? :hmmmm2:
