I'm afraid that's outside the scope of my knowledge
Looks like I have some more research to do.
Well, if you are seeing the twrp screen for a brief moment, the timing isn't the issue... Unfortunately, I'm not able to find an Odin system image. I'll try looking around some more, but unless we can find a system image, or get recovery working, I'm not sure what else to try![]()
I'm afraid i can't view them via my phone and I won't be home for another week to have access to a computer... The last one in the list... All I can see is sys. Does that happen to be system.ext4.tar? (or similar) because if so, that may be what you've been searching for. That would at least repair your system partition... Which would hopefully get you back to a working state
But what type of file is it?:hmmmm2: Also, should I flash it through the PDA slot in Odin?I'm willing to bet the stock lk2.tar is what you want. The system.ext4.img looks to be from a backup made in recovery. (or all least not in Odin format)
Now, keep in mind that i do not own this phone, so i can't say with 100% certainty that stock lk2.tar is the one, but i will say if it were my phone it is the one i would try. And in my past experience with Odin, it would go in pda
Copy that, proceeding with installation, wish me luck. :thumbup:
EDIT* Should I uncheck auto-reboot and pull battery?
It didn't work.....:banghead:Let me know how it goes![]()
Did Odin say pass?
the only other suggestion i have is to try reverb_system_boot_lk2.tar... If that fails I'm afraid your phone may be dead![]()
should I flash this one through the bootloader slot or the PDA slot?
Again, not knowing 100% since i don't have this device... I can't say for sure... But, my gut says PDA. And honestly, at this point what to your have to lose?
based on the size, it's the tar you downloaded before with an additional 8mb of files (hopefully the ones that will solve this problem)
... btw I just want to let you know how grateful I am that I actually got a "guide" to help me out with all of this. THANK YOU SO MUCH :adore:
PS - PLEASE try pda FIRST![]()
Tbh, i don't think trying bootloader, or csc will have positive results... There's no no way the bootloader us 800+mb and csc is usually Country Service Code... But the only other option i see being possibly viable is phone.... But even that i know little about...
Ps - still patiently waiting for confirmation of success/failure
OH NO! I take that as a fail? :'( I'm sorry bro. I wish i had the magic bullet to fix this. I was totally gunning for this to work... I'm sorry man
............. I know I shouldn't say this but I must... AGAIN, THANK YOU SO MUCH FOR EVERYTHING:adore:
Can I do something about this?VanVon, I tossed a odin tar with boot, system, and recovery together. Flash it just like you would the recovery.tar's.
This is M950VPBMI2, so will need a few updates afterwards to be on the latest OTA.
M950VPBMI2.tar
cguru:Can I do something about this?
<ID:0/010> Added!!
<ID:0/010> Odin v.3 engine (ID:10)..
<ID:0/010> File analysis..
<ID:0/010> SetupConnection..
<ID:0/010> Initialzation..
<ID:0/010> Get PIT for mapping..
<ID:0/010> Firmware update start..
<ID:0/010> recovery.img
<ID:0/010> NAND Write Start!!
<ID:0/010> boot.img
<ID:0/010> system.img
<ID:0/010>
<ID:0/010> Complete(Write) operation failed.
<ID:0/010> Added!!
<OSM> All threads completed. (succeed 0 / failed 1)cguru:
How can I tell Odin to stop being a B!@#% to me.
