Root Need SBF help. Urgent!
I'm a new member and first time posting and I already need help! I was on the original GB leak and have SFD'd to get back to stock. I got almost all the way through the process and now I'm stuck at the red eye. It occasionally goes to "droid" and then back to the red eye. RSD Lite says "Please manually power up this phone." Progress is 100% executed, but the Results says "In process..." This has been going on for over 30 minutes now. Need some help here. Thanks in advance.
Easy fix!
Turn phone off
Press and hold home and return key
then press power
wait until you get the triangle
then press magnified glass
go down to wipe data
to select you need to use the power button
after that is done reboot and you should be fine to continue
Good luck!
pull the battery and boot into the STOCK RECOVERY and do a full wipe. DATA and CACHE. that should get you going.
Looks like someone beat me to the punch. hope you get everything back in order
Shut down RSDlite and pull the battery. See if it boots normally. If not, turn your phone off (pull battery), hold down power and the menu button at the same time until you see a android guy and an exclamation point. Hit the search button to get into the stock recovery. Wipe data and then reboot.
Edit: Good help here. Two others typed instructions at the same time. Between us, you should get it working. :)
you may not even need to do the wipe...but if you've gotten to the red eye then the SBF is complete...
i would follow the instructions of the other guys and boot into recovery and wipe (there is no data on your phone to actually wipe so you wont lose anything more)...
