Got my g2 yesterday and I figured out how to unbrick it, which happens to also work for the l9.
I take no credit other than bringing it to you.
1) Download the v10dkdz or v10ekdz
2) Download LG mobile support tool and Install it. (It will open up when its done just CLOSE IT OFF)
3) Download / Install FlashTool (R&D Test Tool) found here. Only download flash tool file.
Directory Listing of //Xda/LG Optimus G Pro/LG Software/
4) Power off your phone, press Volume Up & and then plug in the usb cable (enter to a download mode)
5) Extract FlashTool and run UpTestEX.exe
6) In R&D Test Tool window,
Select Type = 3GQCT (top left hand side)
PhoneMode = DIAG (top right hand side)
Select kdz file = click to select your LG stock rom *.kdz
Click "Normal web upgrade test" (bottom right hand side)
Then another window will pop up, click "Upgrade Start" button
wait a few seconds, another window "Select Country & Language" pop up,
=> Country=Republic of Korea
=> Language=English
you can click ok to proceed
7) All Done and wait for finish!
If you changed the hosts file to use offline method previously, you'll have to open up the hosts file using notepad ran as administrator and delete the last two lines you added, save and restart your computer.
