Root Need some input
woodstorm
Testing a new ROM and have had several problems with Tweetdeck. Got most figured out but am having issue where I get a FC every time a tweet is selected with a tmi extension. Has anyone else seen this issue? I am asking here b/c I am trying to see if this is ROM specific or if Tweetdeck is just going the way of the Mastodon. Thanks for the help.
I am not familiar with tweetdeck but i do know the first thing you can try is to fix permissions in clockwork recovery. That can usually fix fc issues. Also if you are deodexed and themed you can try flashing bouchigos deodexer file.
^^ this. I was gonna say... check permissions on the app. Other than that? Dunno.
