Root need (un)rooting assistance.
I've done some searching on the site and there is a lot of options to unroot the evo 4g, I am selling mine because I have the 3d but I need to unroot it completely for the guy to buy it. All the downloads I have come across are no longer available because of the mega upload shut down or whatever. Does anyone have the zips they can send me to do a full unroot, I lost my system recovery some how when I unrooted my wifes evo when she sold hers.
welcome to the forums!!!!!!!!!!
when you unroot your phone you will be left with the stock recovery which you do not have access to.
we need some info from you. what is your hboot version and what is your baseband? best thing to do is just type in what you see on thebootloader menu. to get there you must power off (make sure that fastboot is disabled, setting>apps>uncheck fastboot) then press and hold power+vol down. this will take you to the bootloader. report back with what you see and then we can point you in the right direction.
I did the first two steps but on the second step after rename and putting it on sd card
it loads but does not ask me to update.
Download and run the RUU (in red text) from that guide. Its a program you run from your comptuer. After that installs your done..
Aw crap the sites down. Its in my drop box lemme get to a computer.
Sent from my PC36100 using Tapatalk 2 Beta-5
