I read some of the stickies. I tried both of your solutions. I first tried the Xiona one, but it kept saying it was bad when I tried to install it...
Then I Sammy's guide and it was good...but it got me back to step 1 where I was at with recovery mode. I saved both instances of the logs so you could read it...
Logs:
Logs.rar
Virus Scan: (I have no reason to send anyone a virus since I actually like this forum...seems user friendly but here you go anyways):
https://www.virustotal.com/url/9d33...b555f1c12e3e61995353e115/analysis/1344711731/
Note:It does say it has a virus...but read the file scan description: The URL response content could not be retrieved or it is some text format (HTML, XML, CSV, TXT, etc.), hence, it was not enqueued for antivirus scanning.
Edit:
I am stuck at Clockwork Mod Recovery screen. So I am back at step one. The Xonia one kept saying could not open file (bad). Sammy's guide helped me get out of emergency mode and back to recovery mode...so it is still bricked?
Edit Once Again: Is it possible Im doing something wrong with Xonia? I don't put it in a specific folder. I just put it on my SD card with no folders. Then I mount the SD card (note: I did try to mount everything that is mountable on) then I go to install the zip and manually select it, but it still says it can't be opened. (Bad) Does (bad) mean it's corrupted and I should format my SD card? Sometimes I have problem with my phone's SD card (Kingston 32 GB) not saving anything. Like if I get a new song or picture it won't save it. I have to format it and then it will start saving things.
