I find after flashing the sdreadahead zip that my phone doesn't sleep do you have that problemFyi...did have to dmflash the sdreadahead zip after flashing this kernel. Both read and write speads dropped.
same here, and yes, just started after flashing the kernel, always right after screen unlock or when turning off 4g. I am going to look at my screen off profile I may have it set too low for this kernel
as for 4g..he only mentioned better 4g behavior. I am unclear what he meant by that.
. I have not idea what he did either. Apparently it didn't involve finding a fix for that bug
.Fyi...did have to dmflash the sdreadahead zip after flashing this kernel. Both read and write speads dropped.
Hi Mr. Ed,
So you flashed the 4.3.2 sbc mor havs and still had the flash the sdreadahead zip anyway?
I just downloaded the netarchy 4.3.2 and I want to make sure I do the sdreadahead if needed.
on a few posts down you mentioned some screen settings and another settings for screen not sleeping... uh where can I find them?
Thank you very much
Charles
