Help New memory card problem
puckman
I had a memory card update due to a lost phone . my new phone went from a 2 - a 8 gig card , now all my camera shots and music are gone how do I transfer one to the other card ? 2-8 card
Your photos and music are gone with the phone. Unless you can remotely access that lost phone, no way to get the files.
I have the phone. the memory card was changed only and i have both cards . how would i put the info back on new card?
Did you install any programs to the SD on your new phone?
If not, you can just put the old SD card in the new phone.
If the new card is an 8GB and you want the larger capacity, then the easiest way is to put the SD card in a reader and copy the files using a PC.
- put the old card in the phone
- plug the phone into your PC
- change the phone to "USB Mass Storage"
- copy any files you want off the card onto your computer
- put new card in phone
- copy those files you saved back to the phone
DONE
