smokinmonkey
Desire, rooted, LeeDroid2.3 (latest)
OK so I got a new 16GB sd card..
I made a titanium backup and a nandroid backup.
I booted into linux (ubuntu10.10) and formatted 500 odd MB as an ext3 partition and the rest as FAT.
(still in Linux) I put my old SD into the computer and copied over all files (including hidden files) to a folder.
- note, in linux when i insert the old SD (formatted in ROM manager when I first rooted) it opens as a single directory... but when I insert my new SD card (formatted in ubuntu) it opens the ext3 and FAT as separate directories -
I copied all the data to the new sd card in linux (to the FAT partition) I insert it to the phone and only have about 5 apps installed. So I insert my old SD and restore a nandroid backup and im back to normal.
I've no idea how I am going to use this new SD card.
I am now currently restoring a nandroid.. I will then install a leedroid without a2sd+, format the new card in ROM manager and then try to copy the backed up data to it then.
Should I be backing up the old SD card in windows or in linux??
