Root Newbie Questions
Can anyone tell me how to get this theme off my phone, unrooted, & back to stock?
Well, you can
1) do a factory data reset
2) Install another theme over it and wipe data and cache
3) sbf back to your rom.
Feel free to ask for further help if necessary.
  • Like
Reactions: RDM
Glad you asked. Firstly I would ask you if you're on android 2.2.1 or 2.2. Then I would direct you to the appropriate files and procedure on how to recover your phone back to stock.
Are you bricked, now?
2.2 & no I'm not bricked yet
sbf is a recovery process if you are bricked. At this point, if I were you, I'd switch to another theme or rom or just do a factory data reset. SBF isn't necessary..
Steven
Steven
Ok! What I did was, unroot with Z4. & installed 928 back to stock de-odexed. How can I tell if I am unrooted & it is out of the ox stock? So I can OTA updates.
I don't think it needs to be unrooted for the OTA, I was able to update last time while rooted. I don't think it needs to be odexed bit it will take your deodexed phone back to odexed
Ok! What does odexed& de-odexted mean. I'm learning a lot here.
Did you make a backup BEFORE you deodexed and applied a theme?
Restoring a backup would be the easiest way back to stock.
No you didn't need to unroot and I've read that deodexed phones got the upgrade. For me, root was broken and I had to reroot after.
Deodexing is required to install themed applications. Odexed is how your phone was when you received it.
  • Like
Reactions: RDM
