Root [Nexus 4 Radios] Flash in Recovery [LTE and HSPA+]
jmar
Nexican
Hey y'all,
I felt like it might be nice to have a place for available radios for the Nexus 4. Hope you are down...
The .24, .27, .33 & Hybrid .33/.84 versions allow for LTE/HSPA+/HSPA/EDGE connectivity.
The .48, .54 & .84 versions offer the same, except no LTE.
This post will be maintained and updated by me or whomever may contribute to this thread. All radios can be downloaded here:
My Dropbox Linky: Download the Radio which fits your needs: .24, .27, .33, Hybrid are LTE capable; .48, .54, .84 are HSPA+ capable
Each T-Mobile market may vary in terms of available coverage and speeds relevant to that market. I guarantee nothing.
I have downloaded and flashed each file with no problems, in hopes of providing a brick-free/bug-free experience; I just can't guarantee it.
Yours,
jmar
MD5s
.24: a52f143750f4d33aeadbcf442a248ddf
.27: e9830971c2ccf792c5901e73cdb7474a
.33: 3607ae33dea2764c44e0e03c44cce7f9
Hybrid .33/.84 (Use with Android 4.3): f14a02321033c8f20b88f6402b9e0e86
.48: a206b6787fdc071614938f0a93a62fc5
.54: 0d556693de6c6af086d8d9a74a5dc164
.84: e7d06690b2e26f2d0c8fa11c69791981
Special thanks to scary alien for his app, find it here: Android File Verifier
.83 radio coming soon! Likely to be another non-LTE radio...but you never know! Seriously though, not likely. :rolleyes:
So it looks like the. 83 radio was not the final radio. .84 is the final radio. I'll post it, later tonight after the little one is in bed, as well as a hybrid of .33 and .84 for those who want LTE.
When i took the OTA, my radio changed to .84 and now i don't get signal inside my home.
With .48 i use to get 2-3 bars all the time inside the house but like i said, now i get no bars inside and when driving around i notice that signal keeps falling in places i use to get full bars all the time.
can i flash back .48 on rooted stock 4.3?
Hey everyone. I flashed the hybrid .84 radio and edited the build.prop. and added the T-Mobile LTE APN and went into the 4636 menu and still no LTE. Any tips?
If you followed the directions exactly and you have LTE in your area it should work. I'm using that radio also and it is working great.
After most of the steps were complete I had to reboot before I could enable LTE, then reboot another time after that to actually connect. But, other than the reboots I just followed the directions exactly and used the hybrid radio
I don't think I have coverage out here in California then /: I'll have to wait til I go to Illinois. Maybe I'll have coverage there.
If you flash a LTE radio is there some way around having to enable LTE manually every time you boot the phone up?
Don't 4G/LTE phones Automatically select whichever band is the strongest for you?
Bruce in Ocala, Fl
Bruce in Ocala, Fl
Because it is disabled in the os, the stock rom will not give you the option. However certain custom roms will allow it to stick if you make a couple changes to the build.prop
And those ROMs that allow it to Stick would be?
Thanks!
Bruce in Ocala, Fl
I remember AOKP allowing it to stick. I also think CM10.2 allowed it to stick so I'd imagine CM11 would as well. I used Carbon and P.A.C-MAN as well and I think it would stick with those as well. Just remember to make the build.prop edits after flashing the rom as illustrated in the stickied walkthrough in the root subforum and it should be good to go, though I think you need to restart the device at least once near the end of the process in order to make the menu show up.
Thanks!
Bruce in Ocala, Fl
Bruce I think I read that you got it working, but would like to say with that enabler zip you posted, and a factory reset even stock rom will allow lte to stick.
The key is the factory reset, once the build prop is edited.
There is a squlite editer that is supposed to get it to stick without factory reset but I never tried it so could not tell you.
I'm not rooted at the moment and have been thinking of rooting and changing radio to try to get better battery life.
Hey y'all,
Yours,
jmar
MD5s
I just flash the radio I want in recovery correct?
