I would suspect Go Launcher right now, too. I haven't installed another launcher yet just for that reason. I'll be looking at Apex shortly.
I got used to Apex from the SuperNexus JB rom I was using on my S2.
Have you looked at the app processes to see what's running, and then try removing apps one at a time to see if you still get the reboots?
If it's an app that's causing the problem, then I'd say a factory reset and running the phone stock fit a few days to see if it continues.
