costarican
I'm running paranoid android 3+ and my WiFi will connect but ewont get data ? Any suggestions ?
In order for your wifi to connect to the router it has a mac address, on your router do you have mac address filtering turned on?I'm running paranoid android 3+ and my WiFi will connect but ewont get data ? Any suggestions ?
You must be running the .33 modem. as with stock android you have to have the latest .48 or use this hack a guy on xda found.i haven't been able to use any version newer than the 02/24/13 build. they all mute my mic and speaker during calls. i always flash over my existing version and clear cache/delvik but it never works.
