When I connect the nexus 4 to the WIndows 8 PC, it starts charging and says its connected with USB by MTP. But the PC does nothing at all.
Yes but will it work next time most reports say it will often fail.Just wanted to chime in again to say that I got my Nexus 4 last night, and today I connected it via USB to my Windows 7 machine.
Drivers were immediately installed, and then AutoPlay popped up asking me if I wanted to access files on the device.
I opened it as a folder and was able to access all the folders and files on the SD card as usual. As I type I am transferring mp3s to my phone.![]()
No problems using XP SP3.Yes but will it work next time most reports say it will often fail.
Same here no problems at all. Windows 7 gives an error of file not being able to play on deviceJust wanted to chime in again to say that I got my Nexus 4 last night, and today I connected it via USB to my Windows 7 machine.
I can transfer on Windows 7 but not with the cable provided with the Nexus, my old HTC Desire cable worked fine though.
Can't say I've ever tried to transfer 750MB files.
I've shifted video files to and from the phone that were around 120MB - 150MB, no problem. I did have issues with file transfers once, but then I changed the USB cable and have had no problems since. Touchwood.
Re MTP: the thing I really like about it is I can continue to listen to podcasts while I'm transferring files. Otherwise, it's pretty much the same as having an old style, USB connection.
I'm planning to buy a Nexus 4 and am reading up on potential problems. I want to be able to transfer movies (e.g. 750mb size files) from my XP SP3 desktop and was worried about the process until I saw your post. Can you just confirm that copying such files by usb cable works well for you with XP?
Linux user #266351. Android since v1.0
I've got XP SP3 and it won't connect; recognises it as a Nexus4 but looks for drivers and fails to find any. However, a laptop running XP Pro connects no problem and I can copy files to the phone okay.
