D
Deleted User
Guest
I was getting an update message, to go from 4.4.4 to 5.0. Now the message disappeared, and my phone says that it's "up to date" at 4.4.4. If i want 5.0, how do i get it? I'm stock, by the way. Thanks.
Honestly, it will take about an hour to get and install the Android SDK (and Java platform if you don't have it already) and about 5 minutes to flash the new firmware.
You mean flashing the factory images?
We can help you with that if you get impatient.Honestly, it will take about an hour to get and install the Android SDK (and Java platform if you don't have it already) and about 5 minutes to flash the new firmware.
Yeah, it's that easy.
I wouldn't be in any hurry to get 5.0.1 and even less for 5.0.
