Help Nexus muted while charging
rsmin
Help. Searched and cant find anything on this problem. Just bought my nexus a few days ago and everything working great except for when i am charging it in the car. I tried two different chargers and both are showing AC while charging but if i call someone they cant hear me, but i can hear them fine? Once i unplug either of the chargers they hear me perfectly. It is as I'd they've phone is muted while being charged? I didn't think to try it with a Bluetooth headset or on speakerphone. Maybe Google fixed this so you can't drive and talk on the phone at the same time?? i love the phone and just hope this is a setting somewhere?
Thanks foe your help and sorry if this has been discussed before. I just can't find it.
Does this happen every time? THere is a one-way phone audio issue that is occuring, but it is more intermittant... Since you have only had it a few days, I would recommend doing a factory reset, and seeing if somewhere an app you installed is causing the problem. If that doesn't fix it, I would exchange it, its possible you got a defective phone.
Thanks for the advice , tried it again last night and it worked ok. Must be intermittent. Will give it a few more tries. I don't have to many apps on this phone yet. Still have a week left on the 14 day deal.
From what I heard the phone is being deemed defective by Verizon for this issue, and they are exchanging it. But remember you will get a refurb in its place.
You can exchange for new in the box within 14 days, after that, you get one that might be new and might be refurbished.
By the way, I am one with the one way audio issue, really annoying btw. However I am wondering, what is the build date of yours?
It's a .10 version. I tried several calls on the way home from work. Really, hit or miss. About 1/2 the calls were bad. Even with the speakerphone it was giving me trouble. With the charger plugged in I made one call and the person on the other end said they could barely here me and when I unplugged the charger they could hear me fine. I have also had it cut out twice not hooked to the charger. Going to call Verizon tonight and try and get a replacement. I love this phone but really need it working with the charger. Everything else seems ok.
