Root nexus one lockscreen xtrrom
Put in the root of your sdcard then flash from recovery. I have used that lockscreen on 4.0.6 on the Xtrsense and on my current 4.2 XtrRom. I have had no problems with this lockscreen.
Yeah, just go to the recovery and flash the zip. reboot and you will see the clear unlock screen with the slide across unlock thing. If you go to another XtrRom you can just put that in the root of the sdcard, then flash the rom, then the lockscreen. works like a charm. enjoy
I don't know where to find the zip, but you may want to try the lockbot pro, or you may be able to just change the lockscreen picture.
I read a thread over at XDA that said the HTC lockscreen is layered on top of the vanilla nexus lockscreen. All you have to do to remove the HTC lockscreen is remove it via Titanium Backup and the vanilla nexus will now be the default lockscreen. The only problem that has been encountered is the HTC alarm clock WILL NOT work if you have removed the HTC lockscreen. I'm also wondering if the music controls will no longer work. I'm going to make a nandroid and try this when I don't need my phone for a few hours. Will report back asap
I haven't done it and prob won't be able to for a few days. I need my phone on at all times because of work.
