Help Nexus S Facebook Sync
daniturn
Does anyone know how to get facebook contact sync on the nexus s and does anyone know where i can find the apk for contact sync that is missing or should i root the phone but dont want to that as its far to complicated and just want stock android and is there a way that if i did root it that i could use the facebook contact sync file?
Thnx
Dan
I rooted and am having trouble getting my contacts to sync up. I don't think it's because I rooted though. I am running cm7.0.3.1 and it's extremely stable. I guess it's a Google vs Facebook think as the guy above stated.
I don't know why you have to do it this long tedious way but I figured it out.
Go into any contact<menu<edit contact<menu<join<choose contact to sync
It's really dumb and tedious but it works.
This doesn't even work for me. When I go iunder settings to my sync options, it only shows gmail. I add facebook as an account, but then it doesn't add it. What the hell gives?
As far as getting the contact pic, I just used syncmypix from the market, and it worked great. But as far as getting the contact info to sync, still no luck for me.
I also use syncmypix and it works very well but does not do the rest as in contact numbers/email ect from facebook as it did with sense for my htc hero and hope there is an app out there that will do the same sort of thing because facebook not liking google is a massive problem when facebook is the most used social network about
