Help no 3g
zoolife
the epic touch was flashed to boost, i had 3g then. wife has the same phone and never had 3g. lately no 3g at all on both of them.was up town several time have full signal(all bars) still no 3g. have changed modems a few times still no 3g. ready to just say the heck with it and try another service. anyone got any thoughts on this. thanks
Last night the sprint network was out like twice maybe its affected in your area too? Im the valley of caili so unless thats thr case then simply ignore this
Ok .. You need a the ga 10 modem on that... Go into settings and about phone and see which modem u have. Its at the end of baseband version
This is a start
Like mine is fl24
Open settings and make sure u have DATa on... I know its stupid but I've seen people make a thread and that be the problem b4...
If thats on click more and see what kind of data you gave it permission to use. Make sure CDMA is checked. Can't remember if thats in ga10 settings but also look around under more for anything that looks questionable
If that's good... Did u ever push ##data# in the dialer and change anything to try to get faster internet? Have u been in the ##data# hidden menu at all with your Msl number?
We are troubleshooting. Just check for the answers to the questions then report back
If your data settings are corrupt you can do a SCRTN reset and have the phone re-setup its connections ##72786# will cause the phone to do its hands free activation process. This can correct issues with data not working.
Yea a boost rep had me use it after I changed all kinds of proxies in the hidden menu testing what will make data faster. Lol then lost all data
tried that and now nothing, says phone has not been activated and my phone number is changed.
It's in post 9
http://androidforums.com/showthread.php?t=686890
[Root One Stop Shop]Roms, Kernels ect..
Pick the rooted one
That's a zip. You do have the ga 10 repack recovery right?
If not let me known and I'll get u one that can go in Odin or mobile Odin
If this doesn't work than it might have taken away your boost flash from Sprint which I know nothing about and you should do that again:(
