Help No Debugging/No Recovery
ZNyght
I've tried using just about every method to fix nothing seems to work, usb debugging is disabled on my phone so I can't connect to of unless you guys know of a way to force connect that could be useful, but my phone is stuck in a boot loop, and the system recovery was replaced with TWRP and I'm running on CM13, but I am lost as what to do, I've tried everything I can think of. A friend told me they think the firmware glitched. Cause while it was charging via pc, I reset the pc cause it was acting weird and it glitched and my phone was still plugged in so I think it glitched my software as well and set it in a soft brick state. Which I know is soft bricked cause the screen still turns on it just stays on the logo screen. But if you can help any I'd greatly appreciate it thanks. Btw this is what I get when I go into recovery mode, the boot logo and then Teamwin then it freezes
Try downloading another ROM. There are so many roms for the Nexus 6. While in TWRP you can transfer files from PC to your device. So transfer a ROM onto the internal storage.
Go into the wipe menu within TWRP and do factory reset. Then try installing the new ROM.
Edit:
Oops. I missed the last line that said TWRP wouldn't boot. I'll have to think about this later when I have a bit of quiet time.
Welcome to our AndroidForums, @ZNyght.
Is your device (Moto G3?) getting far enough into booting TWRP that adb is accessible?
Is fastboot available on your device (i.e., is your bootloader unlocked) [i.e., to re-flash the recovery via fastboot]
No, my Moto G can't access TWRP for some reason, I can access my bootloader but that's it, and it is unlocked and rooted, fastboot doesn't recognize my device either
Edit:
I don't have a Nexus either sorry it is a Moto G 3rd Generation
usb debugging only makes a difference while the android system is running. You can normally adb in recovery (doesn't require usb debugging). As mentioned you might try adb (maybe "adb devices" for starters) while at that recovery screen even though it looks frozen. Sorry if I misunderstood and you already tried this.
Have you successfully used this phone/pc together before with adb or fastboot?
If not, then it might just be a driver problem on pc.
Yes, I used fastboot before to flash my phone and unlock bootloader, but my phone can't connect to pic cause debug mode is disabled
Idk if this is something you are able to do... But I have my PC running dual boot with Windows and Ubuntu. A couple of times I have soft bricked my phones and adb wouldn't see the phone in Windows but I was able to use adb in Ubuntu.
