Help No H+ data speed in uk on S2
james_uk
Hi, only has my s2 3 days, i previously had the htc desire, when i was connected to 3g it always showed as 3G or 3G+, at high speed the htc desire would show as H+
on the s2 (on the same network as before) my data speed only ever shows at 3G+ at the most, i havn't seen it once change to H+ is this right?
James
I've been on both orange and Vodafone with the s2 and have had H+. My brother has an S2 and is on 3 and he also gets H+.
I'm on O2 in the UK (well, GiffGaff actually) and when idle the phone always shows 3G. It changes to H when pulling data across.
Only ever had H+ when I visited Belgium a few weeks ago.
hmm im finding it a bit weird because i haven't changed provider, i am on orange and havn't changed my service plan either, with my htc desire in my house i would get h+ and in work i would get h+
now with the s2 it just says 3g+ at home and in work, it hasn't changed to h+ once.
very odd, not sure what to do or just leave it.
The HTC Desire shouldn't show H+ because it doesn't support HSPA+ - were you rooted by any chance? I wonder if there was some kind of glitch with a custom ROM or something...
i was using gingerbread, not rooted though, i downloaded it from HTC's site as orange didnt make their own so was able to get it direct from htc.
i dont remember if i got h+ on 2.1 or 2.2, i know i did on 2.3 though.
i only ever get 3G+ just now, firmware is 2.3.3. Orange UK
recently flashed to 2.3.5 to test it out and during that time, it displayed H instead of 3G+
I'm not sure if HSPA+ uses the exact same technology as HSPA or not, but if it does then I guess it would theoretically be possible for the HTC Desire to connect to and use a HSPA+ network even though it's not capable of HSPA+ speeds. The Desire maxes out at 7.2mbps, whereas Three's HSPA+ network is capable of 21mbps - so it's about three (no pun intended) times as fast as the Desire can handle.
James
Hi guys, I've got an S2 on T-Mobile mobile (UK) was running gingerbread always had H+ a lot of the time, but since I upgraded to ICS (via kies) I now only get 3G+ not even a sniff of H+, I've had a few other issues with ICS which I've yet to work out. I think it was buggy when t-slowbile released it which is weired considering they were the late network to release ICS. not sure of this helps anybody but I just thought I'd throw it out there B-)
I'm on Virgin which uses Orange/T-Mobile and regularly see H+ when using data. If you go to Settings/About Phone/Status and scroll down you will see the 'Mobile Network Type' and at the moment mine reads HSPA:11 which is H+.
You do need to know that the phone will automatically fall back to 3G when not using data to save battery power so it will only show H+ when data is in use.
If you are still having problems I'd check you operator settings by going to Settings/Wireless and network/More.../Mobile Networks/Access Point Names, this will give the settings which you can check against your service providers recommended settings which should be on their website.
might I fire a Q here. what does this H+ stand for? how is it different from the simple old H?
thank you
H = HSPA (High Speed Packet Access), supporting peak data rates of 14Mbps/5.76Mbps down/up.
H+ = Evolved HSPA, supporting peak rates of 84/22 down/up.
On orange and get +h every day. Only comes up when using data though and never when using wifi. could it be a setting that's not working.
Btw I am on a generic hand set, not An orange branded one
My phone mostly idles on H and then every now and then kicks up to H+ when I'm in the city (Birmingham), I've noticed it about 20% of the time, I really think it depends a lot on the network area, I'm on O2, I think they're slowly upgrading their towers to H+, before the ICS update I'd never seen H+.
I'm running ICS 4.0.3 on T-mobile in the UK. My phone has never show either H or H+, all I have ever seen is G and G+.
When the phone is showing G the Mobile Network Type states UMTS:3. When displaying G+ the Mobile Network Type states HSPA:11.
From SRH990's post then HSPA:11 is H+ but for me this is showing as G+ in the notification bar.
I carried out a speed test and it came in with Download 3.19 mbps, Upload 1.3mbps, latency 119.2ms, browser 4.5ms.
