pacedrum69
ive tried everything...
HELP PLEASE!!!
HELP PLEASE!!!
not one has....any suggestions?anything for a CyanogenMod rom will work
the only other one i have on hand is the original lockscreen, the tabs version.
tabs version?
the original side to unlock. slide the tab left or right
i called it the tabs version because thats how its refrenced in the code
ah i see. transparent i assume? i like that version, just not the transparent. i am sticking with the rotary
non transparent
I tried the link and it sent me into a boot loop. Any thoughts ?
How do I do that ?none what-so-ever
send me a logcat and ill figure it out
I honestly have never used adb...Im a total noob... :-( has anyone got this to work for real??When I say do adb logcat I mean thats what you typw
Adb logcat
Its simple.
I can help if you get me that. Other wise I don't know what the problem is and I can't fix it.
try wiping dalvik.
Sent from my Eris using Tapatalk
did it only take a few seconds to flash it?? Im trying one more time, after wiping Davlik...I got it to work on mine with no problems at all. I did wipe dalvik. It IS transparent on mine, though i assume you can add a wallpaper to it. I haven't tried. I like it transparent.
