Root No Longer Have Data Connection, Please Help!
eric3316
I went to install a theme on CM6 final and now my EVO will not bring up a 3G connection anymore even after flashing a stock rom. It will not connect to data or even show the 3g symbol.
I can still make calls though.
Does anyone know what setting might have changed or anything I can do to get my data back?
I had the same problem yesterday(no 3g or wifi connectivity). It just disappeared suddenly. I ended up calling sprint and they tried everything but could not fix it, so they told me to take it in to one of their stores. I figured they would just run their useless diagnostic check then tell me they will need to reflash it like they always do. So i decided to save myself the 30 mile drive and hour wait and handle it myself. I ended up reflashing it, and it fixed it....for now, but that was freaky.
If anyone knows what this is about please let me know, thanks
I have a full stock device and this happens to me occasionally. To get the 3G symbol / data connection back, I go to menu...settings...wireless & Networks...and then un check mobile networks...wait a seconds, then recheck. or sometimes just waiting some time and doing nothing fixes it. Sometimes the first method I mention results in issue occurring again a few times. On this case, just reset the device seems to work.
First try reflashing the ROM after a FULL wipe. If that doesn't work, restore a sense ROM, call sprint.....they *should* be able to fix it over the phone.
flash back to a sense rom and data reprovision
##3282#
edit
data profile
menu
restore
only works from a sense rom.
curious of why it could have happened other than the radio change and a loss of communication with the towers
