No Moblie Network
yenrod
I can get WiFi BUT no mobile network;
The boxes in WCDMA & Mobile Network/Internet are checked/ticked/selected...
Should I consider repair/replacement ???
I'm on VF-UK
no need to get a replacement yet. That's always the very last step and is extreme.
1 - check apn settings are correct
2 - check that you don't have any widgets like power controls etc which have a mobile data network switch / option. These may be set to off and as such, block the data. Also be careful you don't have 2 somewhere within your 7 home screens. One could be set to on and the other off resulting in mayhem.
3 - An odd solution but often highlights problems - activate wifi hotspot / tethering and try if that forces internet data on...
4 - Try phone with another sim and attempt to connect to data.
5 - check for network outages.... (im thinking giffgaff, tesco mobile, orange likely)
6 - Delete all existing APN's and enter a new one....
7 - Phone HTC
8 - Go to network shop
9 - Do a factory reset
10 - Try for a replacement :)
I'm sorry that I didn't see this thread before I started my own. I have the same problems as you yenrod but I am on T-Mobile UK.
williamj1, I have tried some of the things that you have suggested apart from using another sim but I have had no luck.
I tried 'ticking' the ALWAYS ON MOBILE CONNECTIONS.. & it seems to work...
AFTER a factory reset...
Tho' I dont rate the VF network for connections.. or speed..
they are a joke when it comes to their forum and helping...the APN settings that THEY give online are totally wrong I had to phone up technical and have them email me the settings and even then you have to do it in a certain order and then reboot...and pray..
seriously...praying helps alot lol
