Hi
I have owned a virgin optimus v for several months. It is a great phone. I found out about the Quick Settings (wifi hotspot) free app and I have been using it for a while. I know it probably makes virgin mad I use so much data. Anyway, last week I had some issues with my phone turning off and on by itself and also a few times it froze for a couple minutes. It wasn't a big deal but I called customer service up and they said they would mail me a new(actually it was refurbished) phone in a couple days and I have to mail back my glitched phone. That was easy! I didn't have to beg for one? So I get my new phone activated and start re installing all the games and apps use. I go to toggle on my wifi hotspot in the quick settings and it wont turn on. You can actually see the 3g symbol disappear as I push it on. It says "no network". So i look into the dozens of other wifi hotspot apps and they all do the same thing. The phone automatically turns off 3g data as I try to turn on wifi hotspot. This must be a virgin update to stop me from using wifi hotspot settings.
I look at the menu under "phone info" on my NEWER phone says.....
-android version 2.2.2
-sw version vm670z5
older phone that works with wifi hotspot says...
-android version 2.2.1
-sw version vm670z4
Can anyone help me? Do you know an app that will work with the new version. Is there anything in the settings I can do to get wifi hotspot back please???
-thanks
-sw version vm670z5
-sw version vm670z4
-thanks
