Root No radio ?
genovdot
Android Expert
Well, my esteem was in test mode. I fixed that. After I fixed test mode I switched my number to it ( had a freeform before this) cause I figured it needed my number on it to restore the service. Well, web works, I can browse my arse off, but cant make calls or receive them. Nor text. I downloaded an app to check the stats of my phone and it said the radio isn't active. Is there a radio zip or kernel I can flash to fix this. I'm running #2. Thanks in advance
Used this guide a few times and it never worked. So I just don't use this phone anymore.
wasn't there another way to fix radio problems by using anycut? going to the lte settings and doing something..? i forget it's been forever lol
