Got miui installed and I have no ringtone or notification tone on my phone now. If I open up settings and then select ringtone all I get is a force close. Any suggestions? Need help on this one. Business day and got to have my ringer.![]()
Thanks everyone! I did all the wipes before doing the install...including the dalvik wipe.
Where can I get the previous version at? Also, if I am on 1.8.12, to install the previous version I just reboot into cwr and install it? And to get into cwr do I need a certain terminal app to get there or will any do?
Ringdroid question. Downloaded and installed it, but it just looks like a ringtone recorder/editing program...how to you set your phone ringtone with Ringdroid? I already have my custom ringtones on my sdcard.
Do you have mount the system in cwr during the installation?
MIUI.us_Shadow_1.7.22_Eng_Deo_ZipA_Signed_Framework43.zip I uploaded the best version IMO the original .22 flash the patch as well MIUI.us_Shadow_1.7.22.1_Framework43-signed.zip
And I think you can just flash over since it will replace all the files. I am going to try it in a second and edit the post to let you know.
To boot into recovery get ROM manager and flash the clockworkmod for the droid x 2nd init. Then reboot recovery. NO droid x/2 bootstrap.
With Ringdroid open it and all the files you see there should be every media file you have on your phone. system ringtones/notifications are at the bottom of the list. Long press on which one you want to apply then it will say set as default notification/ringtone depending on what it is.
Never mounted system in CWM but like I said I will let you know.
Download those two files. The first one is the original .22 and the second is the patch for .22.1. Be on .340 stock rooted and bootstrapped. Wipe data/cache. Install the first then the second file. reboot and you should be good to go. That's the best version IMO
Never had them not work. With the camera the widescreen doesn't work but just up the resolution and you're good to go. With the market I never had a problem
Well keep in mind that this is the original version with the patch out. There are three other versions that followed this but I've found this one to be the best with no airplane mode bug
