...how 'bout now? I tried the Motofail method and could not get my Droid3 to generate a bug report. Vol+ and power didn't do it, nor did Vol- and power. I proceeded anyway..."exploit failed"
Motofail still works - I used it last week. You need to unzip the file that you download and run the run.bat file from the folder/directory you unzipped into. Also, of course, you need to enable USB debugging in settings-applications-development.
Just start the phone as normal, connect to the pc, run the batch file.
