myshkin
Hmmm, I changed launchers from Launcher Pro to Go Launcer Ex to go with the ICS theme. Just because he said he was using Go Launcher Ex and there were a few minor little details that I didn't have that his screen shots showed (didn't make a difference). Since then when my phone is on the screen lock you see a message that says, No SIM card, Emergency calls only, Please insert a SIM card. However I just got through talking to one of my daughters, I have been texting, I downloaded a few things off the play store and looked something up on Google. The only problem I'm actually having is I can't turn my data on. I have one new app...Local App...and first thing you have to do is enter your zip code. I try and it tells me I have to have internet connection. Okay, I do, but if you're not seeing it, I will just enable data and turn off wifi. When I go down to turn on my data through settings I get a pop up saying, The process com.android.phone has stopped unexpectedly. Please try again. I also can't enable data through a data widget. I press it and nothing happens. If anyone knows what is going on here I'm game to fixing it, if not, I guess I need to uninstall that theme.Thanks, Anna
