Help No SIM Card Issue
Kaze11
Im getting so frustrated! Why is it saying no sim card inserted?! Wen i flash it to stock same o thing!!:(:(
Try the following.
1) Un-mount the SDcard(if given the option to do so) & remove SDcard from phone.
2) Turn off the phone & remove the battery
3) Re-install the battery & turn phone back on
4) Re-Install the SDcard & hopefully the phone will recognize that the card is now installed.
Try the following.
U Read The Post Wrong! Im Not Having Trouble With The SDcard! I Have NO NETWORK/SERVICE! It SAYS NO SIM CARD! Idk WHY ITS SAYING SIM CARD CUZ OBVIOUSLY CRICKET IS A CDMA CARRIER
My sincerest apologies for misreading your post.I'm definitely not accustomed to seeing posts about SIM cards in this forum,so,please accept my apologies.
I believe there is something similar,though factory installed & non-removable called the UIM card.
Why you are getting a SIM card error,I can only guess that it is somehow related to when you tried to install the Chinese version of 2.2 & it was intended for GSM phones w/a SIM card.
Again,my deepest apologies for misreading your initial post on the SIM card error.Hopefully,someone who has encountered this problem & has made it through the ordeal will offer their assistance here.
thats new to me, never heard of a sim card on stock, sounds weird....
did you flash metro recovery or cricket?
SIM = UIM on CDMA phones.
To me sounds like a bad flash n I would reflash if it were me.
THX for dropping by,PlayfulGod! We know you've been busy @ the sub-forum 'ALL THINGS ROOT',testing the latest in CM7 Gingerbread updates.We definitely appreciate your input on this side as well,you're an esteemed member of the ASCEND community in the main forum as well.Don't be such a stranger,when you find time. :)
What did you use to cause this? I got a UIM and then a SIM error when I tried to use an APN manager. You are possibly going to have to put a new CWM on it. Then try flashing another rom. I was able to go back to stock and have it go away but, If it's not going away on stock for you...Then your going to have to do it the hard way. :[
Use this is you on metro, using fastboot...MetroStockRecovery-SCRIPTS.zip
http://androidforums.com/huawei-ascend/282038-how-flash-huawei-ascend-stock.html
Jazziette:
These directions are for Cricket
the previous post contains directions for MetroPCS
Force Update Method
(Recommendation : When the OS of handsets could not start up successfully)
Download the Following Package:
http://www.filedropper.com/m860v100r001c153b251sp03
1) Copy "dload" folder to SD card
2) Switch off the handset ,then press "Volume Control Upper Key +End Key+ Power Key"
3) Showing successful
4) Remove battery one second ,then power on ,waiting till the os start up
Normal Update Method
2) Settings--SD card & Phone storage--Software Upgrade
*Don't know if you read this or not. I don't know if it would help or not but I'm trying.
