I had used TB to move user apps to SD, I had noticed that this did something to my voicemail widget, so i went back in to restore that back to internal and then i did a reboot to see if it cleared it up.
I've been pulling battery so it will shut down and i can get to recovery, i will try removing sd card also. I think my card is a piece, its been weird since i started playing around here.
I can now see but, how can i restore it?
in recovery select backup and restore and then select restore and find your nandroid backup. it is usually listed by date.
The only way I can see it when toggling is when I am hooked to laptop with cable, otherwise I'm not seeing anything except the recorvery screen telling me it is enabled.
Restore says it can't read/access card
ok so in recovery then i would backup the card on the computer. reformat the card and then paste the card back and see if that helps.
After the format should I just reboot first or go ahead and go for a nandroid restore?
Actually, thought i could format in recovery, nope. How can I format the card?
you can reformat you card on your computer.
and yes after it is reformatted you can then try the nandroid backup restore. no need to boot up.
How would i reformat, sorry to be a bother.
Never mind, I'm a little panicked and my brain isn't working fully. Will i need to re-partition?
