Root No USB Mass Storage
So I decided to replace Ubuntu 11.04 (wasnt liking Unity) with Fedora 15 (I was really liking Gnome Shell). By the way, Fedora 15 is really freaking nice
Anyways, now i cant use USB mass storage any more! it doesnt even come up in the notification menu and i cant get in from the settings menu either =/
Any ideas? Missing driver? I have no idea.
Nothing has changed with my phone, just my OS. God, i need a linux user up here xD
Thanks in advance.
Thanks in advance.
Type lsusb in the terminal and see if it lists your phone. Sounds like a permissions issue
Thanks in advance.
If you like fedora great keep it but if you like ubuntu 11.04 but hate unity there is a way to go back to gnome.
in system login you can choose ubuntu classic.
I know unity drove me batty I was searching high an low to change it even when so far as to remove unity then found it was not needed. Didnt work well either.
Awesome, but now i still have no idea xD
Code:
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 002: ID 1bcf:000a Sunplus Innovation Technology Inc.
Bus 004 Device 003: ID 413c:2005 Dell Computer Corp. RT7D50 Keyboard
Bus 002 Device 002: ID 1004:6000 LG Electronics, Inc. VX4400/VX6000 Cellphone
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
That's the output of lsusb. The second last one is my phone.
@new metro, arent i free to choose my OS as i like? I thought i'd give Gnome Shell 3.01 and fedora a chance. I havent used Fedora in 5-6 years. Also, comment very unrelated, didnt help me much =/
Code:
Check this folder:
/etc/udev/rules.d/
There should be a file there called 40-udev.rules
The number might differ in you distro. Open that file with a text editor and post what permissions are set. Should say MODE="0666" or something
Check this folder:
/etc/udev/rules.d/
Thanks man, I got it to work! kudos!
