Old Member
Android Expert
I live in the Cincinnati area and have had no data connectivity 3G or 4G since around 6:00 pm. I'm wondering if anyone else is having this issue. Let's keep this thread to report and post data connectivity loss.
I've changed it from 3G/4G to CDMA only. I've rebooted several times. Nothing worked. At 9:30 tonight it suddenly all came back. Makes me think it was a Verizon Wireless issue.
check your settings. make sure the data is turned on. the bars will disappear for a second on my GN, but they come back without data unless i turn it back on in the settings.
doesn't happen often, just an ICS bug.
Bubba - is what I'm describing in this thread what's happening to you? I don't want to assume it's the same thing, but I only point it out because if what you're seeing is what I describe there, I'm fairly sure it's a hardware thing. I'd hate for you to get stuck with it or have to deal with a warranty replacement via Samsung if you could get it addressed now. May be too late now with the 15th having come and gone, but figured I'd let you know.
OP - sounds like it was just a VZW hiccup. Unless it happens again, I wouldn't worry too much about it![]()
lol
i think yours is a little different. my bars vanish for about 30 secs, then come back with no 4g showing. i then go into settings to find data has been unchecked. it doesn't happen much, but it as occurred on my other three GN's too which makes me think it's software, or even possibly network related because it always seems to happen in the same location.....lol
