Root Nook Color Parse Error
coltech88
Hi
I just rooted a Nook Color with CM-7 and have some apps working, but when I try to install others I get a "Parse Error" - "There is a problem parsing the package."
I don't have Google Play to download apps, so I have downloaded the apk files into the download folder and this is the location from which I am trying to install the applications. I was successful in installing Angry Birds from a list of about 15 apps, but nothing else.
I don't have a clue as to what to do about this.
The trackback URL is to the video that I used for instructions on how to root the tablet.
Welcome to the forums coltech. :ciao:
I asked a mod to move this to the B&N NOOKcolor forum where you can get better help.
When you put CM7 on your nook, did you also flash the gapps file?
