I go back and forth between the Sharp ROM, MTDEV-CM7 and MTDEV-CM9. If I backup all three and am using CM9 for example, when I try to restore Sharp, I get the following lines:
CWN-based Recovery v5.0.2.6
Checking MD5 sums...
Erasing boot before restore
Restoring boot image
System image not found. Skipping restore of /system
data.img not found. skipping restore of /data
.android_secure.img not found. skipping restore of /sdcard/.android_secure
cache.img not found. skipping restore of /cache
sd-ext.img not found. Skipping restore of /sd-ext
Restore complete!
But nothing has been restored.
I also tried restoring with CWM5.5.04 with same result.
I then tried backing up with 5.5.0.4 and it went through all the backup steps, but left no file. Any suggestions or is restoring between Sharp and CM9 not doable?
Restore complete!
