wb2ibo
I am having problems in doing an SBF.
At first I thought it was a problem with Vista so I loaded RSD Lite on to an XP PC.
I loaded drivers Motorola_End_User_Driver_Installation_05_11_10_32 bit_4.6.0
I tried RSD Lite versions 4.7 with patch, 4.8 and 4.9
4.9 definitely did not work. 4.7 and 4.8 shows on line 1, Model=S Flash OMAP3630MI Port No.=1 Port Type=USB IMEI/ESN/MEID N/A Status Connected the rest of the columns are blank.
When I Highlight the line Device properties shows some infomation but most of it has N/A displayed after the description.
My DX boot loader is 30.04
The SBF file that I have tried to load is VRZ_MB810_2.3.34_1FF_01.sbf
I would have used CW to recover but it will not come up due to a factory reset procedure.
I can access the SD card through the phone if this helps.
I looked at the SBF logs and they give me the impression that the phone is not responding to commands issued by RSD Lite. Now being able to read and write to the SD card leads me to believe the drivers are working.
When trying to load the SBF the program just sits there and I let it go for an hour on each upload try.
Needless to say I stumped with this one.
Harry
Harry
I found that it has problems with some Routers so I will have to set it up between my router and DSL modem. I think that will fix it.
