how to change the stupid dark grey "box" background at the bottom of the screen? Ive never have figured out where in the hell it is.
Have you checked to see if its being pulled from framework ? Or the dialerapk?
Sorry.....A Little off topic, but what theme is this dialer from.....I really like how it looks,sweet!![]()
Not done with the contacts but finished with the mmsHave you checked to see if its being pulled from framework ? Or the dialerapk?
You know what. I think its not a png, i think its colour code in an XML. I wanna say I remember playing with it.
Happened to remember which one out of the 1000s and in which apk? Ahaha
I can't seem to find it in framework. We don't have a dialer. Apk only phone. Apk I checked that and nothing so I give up lol
It's in Phone.apk\res\drawable-hdpi
Should be able to edit with gimp.
Im home from work. You got it yet?
I dont know if it helps but i know that alot of things like that are 1 pixel thick .9's in the framework or systemui that have completely obscure names. You might check those two out in the hdpi it will be easier to start there and rule those out first i would think. You might even try contacts.apk as well as the phone.apk just in case.
Also you said you got the mms? I believe there is a similar grey bar that engulfs the area where the text you type shows up. Might figure out the name of that one and what it originally looked like and look for similar ones in the above meantioned.
Yesssssssssssssssssssssssss!!! Got it!
Yes please share the dialer when finished. It looks NICE!
So shiny this will updated on Fuzzys theme thread right can't wait stuff looks amazing thanks again and fuzzy you guys rock
I was just doing them for me but will probably release them or just give them to Fuzzy if he wants to add them to his theme![]()
