Root Not enough space glitch.
syi
How do I fix this again? Trying to install an app. Have 3gb free on internal. 1.8gb system. 29extSD. tried wiping cache+delvik.
I'm at my wits end here. I've cleared space, wiped dalvik+cache, used apps. Nothing is working. I guess I have to recover to fix it for now.
Personally, I'd back all your stuff up with app of choice, and load up a fresh flash of the Rom. Restore from there. This has been going on for too long not to see improvement with the steps you've taken.
Its not just me. Its been happening since the move to play. So far only a full wipe seems to bandaid it.
Ok restored to stock. Apps installing right again. All seems good. For future reference if I just need to update prl&profile I can just fast boot right?
Now when I go back to cm10 do I wipe everything or just factory?
Connection seems way worse on stock. How do I check to see if everything went ok with prl&profile?
When you go back to CM10 wipe everything. Don't forget to fastboot flash the kernel if you're s-on. The only thing I can think of to check if prl/profile updated is settings>about phone, somewhere in there gives the prl version and whatnot.
HOLY [expletive deleted]. updating prl&profile and doing full wipes really fixed stuff. connection is actually fast and Google now works finally. thanks guys.
I'm not certain of the latest version, but it would seem you have the latest version judging by your second post there. Good to see you're up and running.
