not to impressed
Just switched to the m from the lg lucid and I'm not to impressed with the software.
Not being able to switch themes the copy/paste is all weird. Can't run half the stuff I was able to. I'm sceptical on rooting it because bad experiences i n the passed. And all the damn bloatware.
Most of the bloat can be disabled without root.
Settings, apps (all), select app, uninstall updates if the option is there, then select disable.
